Upper Control Arm, bushings and Upper & Lower ball joint Recommendations?
rklewis1005
1:18 PM
1970 Dodge Charger SEw/383HP and Auto
Mine are putted/rusted so looking for recommendations or warnings for Upper Control Arms. Want the OEM look - not tubular.
Also need Lower Ball Joint recommendations / warnings.
So many to choose from and appreciate info from real people using them on real cars. Just for cruising not building a drag car.
Thanks in advance
Ross
If you would like to go with the very best Quality in the year 2025,
P.M. me , as per forum rules, if interested......
Yours, Craig........
I heard someone on the site said AC Delco was still good. Bushings I havent heard complaints.
Since Moog went to hell a few years ago, I switched to Proforged stuff, and knock on wood, it has been good. That said, if Craig can get you some USA made pieces, I would go that route.
I just Googled ProForged to see where they are made ( you can do it , also ...)
It is indicated India , Turkey , China , and Taiwan..... ( check it out ... )
Are those four cities in Michigan ???? ( I doubt it .... )
Who has an actual early Mopar that has used Moog ball joints or bushings that has failed? I have not.
It's been discussed since at least 2013. See this thread.
