PurpleBeeper
Well, I got it gentlemen THANK YOU. I had to run a 3/8" tap in the hole (in door crease) turning it with a small vise grip. I then used a 1-1/4" bolt with threads all the way down & it tightened up.
FYI- the reason I have to shim in that area is this car was t-boned by a full size Lincoln right in the a-pillar. It was straightened & looks OK, but some stuff in that area is just "off" a little bit.
