I ordered the sr687 linkage from year one for my 69 super bee. Rods and arms do not look like the stock at all. Of course no instructions. Any help would be appreciated.
Here are 2 pics of my setup - taken 2 years ago. I discovered that my reverse rod was installed incorrectly (shift plate is upside-down) - corrected now.
Don't forget you will need new bushes for the rod ends.
I bought that kit and then ended up reselling it on ebay. It is a universal kit that is supposed to work with several years, but not exactly correct for any. It will work though, and when set up the reverse rod adjustment threads will be to their max lengthwise. I ended up buying a correct one from Brewers that is much better quality with no slop between rods, levers, and shifter.
