Huskie007
:angryfire:
I just installed a new power booster.
I connected the vacuum tube coming out of my PCV value to the vacuum port on the back of 750 double pumper.
I connected the power booster vacuum line to the manifold vacuum port of the edelbrock manifold. It was plugged, but removed the plug and installed a port to connect the vacuum line.
The car ran great for a while, then started to sputter at higher speeds and then was sluggish of line...
I am not sure if I have the vacuum lines connected right?
When I removed my old power booster that lost vacuum, old power booster... the vacuum line was connected to back of the carb and tube coming from the PCV was open and running to the side of engine to drain if need, and the manifold vacuum port was plugged.
trying to figure why it ran great for a while then it started running really crappy... I felt I wasn't going to make it home.
