This is the line and grommet that goes from the intake through the firewall to the heater vacuum control. Does anyone make these or should I just hollow out the center and run vac. line through it Thanks
Pull the old vacuum line out. Put the grommet back in with a new vacuum line. You don't need to hollow anything out. It is just a tight fit. I take some hand cleaner and clean and soften up the grommet. Just scrub it like you would with your greasy hands. It will come out like new. I use Wisk hand cleaner without the grit. The lanolin softens the rubber up real nice.
