Nothing but net , from the 3 point line.I hear ya! Ya find 'em everywhere!
I'm drinking water, just not out of your trough. I'm still waiting to see why one is better than the other.What's that saying.......
You can lead the horse to the water, but you cannot...
Ported vacuum advance vs manifold vacuum source for the distributor......too many "expert opinions" based on what????.....it's "my way is better than your way....because I said so".....or.......hundreds of engineering hours were spent on the development of the correct application for each engine application, albelt emission requirements or performance requirements.......let's see some real data not just unfounded speculation or the "shade tree mechanic" approach of guess and bygolly.......why not just recurve the mechanical advance and eliminate the distributor vacuum advance all together?????.........I'm drinking water, just not out of your trough. I'm still waiting to see why one is better than the other.
you don't need MVA you have plenty of timing at idle I am surprised it does not turn over slow when hot trying to start it.I'm at 21 using PVA. Why do I need MVA again?
I think we are arguing the same point. That article on MVA is directed at stock or near stock engines with with little initial advance. The benefit of it being that they don't need to recurve their distributor and can still get more advance at idle. For those that build our engines and recurve our distributors, MVA is not needed.I ger it, you don't.
No Chrys engine ever came from the factory with 21* of initial timing. You have increased your init timing to 21*, which is duplicating what MVA would do. Engine doesn't care how it gets it's timing, as long as it gets it.......
So you have realised the benefits.....
The examples I provided [ above ] are based on factory initial timing [ typically 6-12* BTDC ] & the extra idle idle timing ADDED using MVA.
GM were smart. They used MVA until forced to use PVA because of emissions. My GTO came with a small cam 197* @ 050, 10.75:1 CR, but still left the showroom floor idling at 26* [ 6* init + 20* MVA ]. See below.
It is easy to see why bigger cams, low CRs, both need more idle timing, as much as 50*. The benefit of MVA v fixed [ locked ] timing is that is load sensitive & reduces timing with load at lower rpms.
Exerpted references from unknown sources mean nothing.....show us where your references came from.......looks like a hodge-page of cherry picked notes and clippings from several magazine articles. Were the references from SAE sources or otherwise manufactured sources to reiterate your opinion.......inquiring minds want to know......Bob [ Post #23 ].
How many direct comparisons of MVA v PVA, showing the benefits of MVA, are necessary for a Bob Renton 'expert opinion'.
Would four be enough? Some people are slow learners....
Painting with a broad brush saying MVA is better than PVA is just confusing and incorrect.
