am3rican
I have a 1968 plymouth roadrunner with 440 6-bbl. It had factory manual brakes. I recently converted to power disc brakes, all four corners. At the same time, I replaced the throttle body gaskets on 2 of the 3 carbs.
My booster requires 16-18 inches of vacuum to operate properly. With my stage 3 crower cam, I'm getting 12 psi at idle. I checked for vacuum leak and could not find one.
Couple questions:
Is it normal for vacuum to increase when in Park? It will drop from 15 to 12 inches when in drive.
I disconnected the hose to the power booster and plugged it, vacuum dropped to 5. Not sure if this is normal.
I want to avoid getting a vacuum pump. Will a canister get me the difference?
Couple questions:
