Mopartisus
Ok, that makes more sense. Will do!It can also cause the pan to flex and crack over time just like any piece of tin flopping around. Years ago big blocks had foil covered insulation between the intake and the valley pan.
Root cause analysis. Find the leak/where it's coming from.
A leak will likely pool at the rear of the pan. Don't wipe anything off. Take the intake off, turn it over and inspect it for oil around the ports. Also inspect the top side of the pan for any oil leaking from the head intake ports. Take the pan off and inspect it for a crack.
