MADCIMA
What is the correct valve height measurement as in the photo? I have to rectify the new valve seat
I believe it is 1 5/8 to 1 11/16 to the bottom of the retainer. Thats what my 69 FSM said for the 273, 318, 340.How high should the spring be?It's not clear in the manual, you need a tool
Thanks for this, would you happen to have the big block specs?Installed valve stem height, which is measured from the spring seat (NOT the top of the guide), to the stem tip, not the retainer. The measurement for In/Ex is 1.891" to 1.921". The valve spring installed height is measured from the valve spring seat again, to the underside of an installed spring retainer with locks. The installed spring height is 1.625" to 1.688" for the intake, and 1.453" to 1.516" for the exhaust. This is when the exhaust uses rotator retainers. If the exhaust uses the same retainers as the intake, then use the same spec for intake and exhaust.
