Vintage Steel Wheel Source
khryslerkid
10:16 PM
Hanover, Pennslyvania
Looking for replacement, period correct, steel wheels for my '62 Dodge.
I've seen the Wheel Vintiques that Summit and Jegs have. Are there any other outfits out there?
Thanks in advance!
Thanks in advance!
Are you looking for O.E.M. wheels as in what was on car when delivered ?
Are you looking for the 14x5.5 with deep offset, and hole drilled for pin alignment?
Going for the 15" wheel. Like the look of the taller wheel.
The pin hole isn't important. I'll be going with 5.5"x 15" for the front and 8"x 15" for the rear...
I like this look for the rear, stock width for front. (Not mine)
The wheel vintiques are good wheels. I bought a pair several years ago from Summit. Had the tires mounted, and balanced, and shipped right to my door.
This.
The hubcap center is later model and incorrect for our early B's but they fit and work perfectly.
This.
That's what I don't want, a '70s style look. Unless that's my only option for the measurements I'm looking for...
Here is what the 15x8 Wheel Vintiques look like on a '63 330.
...and here is what they look like with the early hubcap (that doesnt fit).
The only other way to get the large hubcap center on the 15" is to use Dodge D100 van rims. They are scarce but still out there.
Do you need new?
watch ebay , i got a set 5 of dippo cop rims cheap already blasted and painted. Call some boneyards, post up in the wanted section... I found these for the price of one new rim and they look sweet on the 64. .
