The only thing I can say is all the voltmeters I have ever seen in cars were hooked up to key on voltage and were not hot with the key off. Of course voltmeters get hooked in paralell where ammeters are in series. The easiest place to hook a voltmeter on a Mopar to me is to tap into the J2 circuit and ground the other voltmeter lead. All the 70 Mopars used the J2 12 volt circuit to the voltage regulator so it monitered the volts from there to adjust the regulator settings and maintain battery charging volts. So it makes sense to me to just tap into the J2 circuit for a voltmeter and it will only work with the key on. Ron
The only thing I don't like about tapping into J2 (dark blue, ignition run, or IGN 1) is that it is not fused anywhere. The way some guys do added wiring, it would be safer to use the fuse panel
. Easyrider, if you're gonna hook something up to the fuse box, hook on the back side, where the spade connections are. I dont remember off the top of my head if there is an ignition switched circuit there, but the gauge cluster light IS there and you'll need that if you plan on this gauge being lit and dimmable with the dimmer switch. In my 69 B body its the 1st circuit on the left (from the back side of the fuse box) and has orange wire coming off it.
But thanks for making my point. The dash lights are always a fuse by itself, fed with a tan, and with several orange wires coming off the output. The dash light fuse IS NOT HOT until the headlight switch is either on park or head. What I mean is, if you are poking around looking for power, the dash lights must be on.
So far as gauge power, the rest is correct.
Below is the rear of a fuse panel, 67 Coronet. This is just as example
The dimmer fuse is at far right. Tan is INcoming power from the headlight switch, orange is OUTPUT to dimmer controlled lamps
Notice how the two left hand fuses are connected at the top, and the third is jumpered as well . You can SEE this looking at the panel, it's a brass strip in there. these are the "hot buss" fuses --- the ones that are hot at all times
Notice how the next two fuses are connected at top. These are "switched" fuses, and hot when the ignition is in "run" or "acessory" One of these three is where you need to pull power for your voltmeter
Your panel may be different. You want to connect at the BOTTOM of the fuses, as the top is incoming power, bottom is fused power going out. IF there is no place to connect a push-on connector at the bottom line then do so at the top buss, but ADD a small inline fuse. Most fuse holders you buy come with a 20A fuse, way too big. Replace it with nothing larger than about a 2 or 5A, but 1/2 amp is oodles big for a voltmeter.
