I have a factory air 67 GTX that some may remember my adventure with last winter in switching over from an electronic voltage regulator to a mechanical one to get my system voltage levels down from 15+ volts to 14 volts. It took a new, rebuilt alternator in addition to the mech VR but I finally got everything squared away. Or so I thought.
I’ve been replacing the interior in the car this spring and summer and finally completed it this week. Backed the car out to run up to the corner and get some gas and thought I would kick in the AC to exercise it. When I did, my voltage gauge dropped from 14 to 11.5-12 volts. Reving the engine up or driving down the road didn’t change it significantly. Turning the AC off kicked the voltage up to 14 immediately. I have an idle solenoid on the engine wired to the compressor to kick the idle up a couple hundred rpm but it makes no difference. My dash charging gauge continued to show a slight charge during all of this. Cycling the AC off and on didn’t make much difference.
Anyone got any ideas on what’s going on with this? I’ve started the car numerous times to back it in and out of the garage while working on it for several months so I doubt my battery is fully charged. First thing I’m going to do is charge it. I may have to go back to that blasted electronic VR!
