Well, no joy in Mudville. After struggling through a bulkhead connector replacement I still seem to have the same problem. At least I did get some peace of mind from that work as I found this.
After I got it back together and started it up I did notice that my running voltage levels are basically dependent upon AC fan speed. With air on the voltage loss on low fan speed is negligable. Put it on medium speed and the voltage drops 1 - 1-1/2 volt. Put it on high speed and it drops 2 - 3 volts. I can’t test on max right now as my linkage is out of adjustment and I haven’t got around to it yet. The alternator gauge is in sync with the voltage gauge and starts showing a discharge as the voltage sinks to 12 or even lower.
I tried the heater setting and found the fan didn’t work. That turned out to be a blown fuse and replacing it brought the fan back in operation on heat.
Took the mechanical voltage regulator off and put the old 15 volt electronic one on but had the same results. At idle with air on I’m down to about 12 volts. Turn on the lights and lose another little bit.
With AC off the lights drop the voltage slightly at idle - pretty normal. I don’t have any relay modifications. Pulled the AC compressor connection apart in the engine bay and cleaned it up but that seems to make no difference. I suspected the clutch before but not now as at low fan speed the voltage drop with AC on is little. I don’t think compressor clutch pull would change with fan setting.
Although the fan motor works I’m now beginning to suspect it. But it does run and responds to speed settings. Can it create that much resistance to pull voltage down and still run?
Any suggestions appreciated.
