hello got an offer on a 67 bel wagon that's very rusty but runs good my question is will body and floor metal work from a 2 or 4 door on the wagon and who has them,thanks
Two doors and 4 doors share nearly all under the skin sheet metal such as:
front inner fenders
Firewall
Cowl
front floor pans
inner and outer front door posts
rear footwells
rear floor pans
trunk floor
front and rear frame rails
However when you go to a SW....I believe the variance starts somewhere around either the rear footwells or the rear floor pan. I believe the SW had a longer wheelbase.
That being said, your best bet is to find a clean 4 door donor as you pick up benefits such as the windshield and doors (as long as it's the same model year). Otherwise....there are a lot of new panels you can get from AMD or Goodmark that will help repair your SW.
I also believe that the 66-70 SW's were pretty much identical underneath the outer skin....so they would be great donors if you could find one.
