Glenwood
- 9:37 AM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Does anyone know where the warm lever cable connects? I recently repaired the vacuum ports with rivets & epoxy. When I removed the assembly, I discovered the cable was not connected to anything. The cable hold bracket was missing from the assembly so I made up something and attached the cable to the lever, but I cannot find where the other end should go. I thought it would be for a cold air damper to mix with hot air, but that seems to be a vacuum operated damper near the right door jam when the COLD button is pressed. Both old manuals I have do not show any pictures or diagrams of the heating controls.
At least the vacuum dampers all work good now without any vacuum leaks!
