72redbird
- 8:07 PM
- Feb 24, 2016
- albuquerque new mexico
When I built the 383 in my wifes Road Runner years ago, I built it a little on the tight side. Got the car up and running during the month of May when it is staring to warm up around here. Car would run a little warm on her driver home from work. I used a product by a company called BG, and the stuff worked. It lowered her temps 10-15 degrees, which really helped out when it hit June and she had to start using the A/C. I left the stuff in there for a couple of years and then flushed the cooling system. Went back to a 50/50 mix and been fine ever since. In my situation it worked as intended, I would say if you are having an actual over heating issue, it is not going to help with that.
