What are these called?
rjbsj
2:33 PM
NC
Quick question, what are these moldings called on the rear of the 69 Coronet. Both of mine have been removed ( I have them) and getting ready to start the bodywork. Looks like they are held in place with inserts that go into the body. I need to find a source for the inserts to replace, but I’m not sure what the trim piece is called to even look them up. Thanks in advance.
They should have studs and are held on by nuts.
Maybe I need to re-look at mine. It looked like just studs sticking off the back, but not threaded. Hopefully I was wrong.
OK, just looked them up online and looks like a gasket is needed as well. Thanks so much for the information again
They are called "Tinnerman nuts". The ones for the quarter extensions have a tall "Acorn" style cap and will also need to use a sealing putty to keep the water out.
Thanks again for the help. I verified and they definitely are Studds with threads like y’all said. I had four of the 10 acorn nuts so I ordered more as well as the gaskets. Another problem y’all solved for me. Thanks again.
