What are these called?
Biopack
3:59 PM
Maryland
The center console has these two plastic tie wrap type of straps on both sides. These straps have the seat belt go through to prevent it from dropping down. Mine broke and not sure what they are called to find replacements. This came off a 73 Charger. Thanks.
I have had 3, 73 Chargers, and a 72 Satellite all console cars and none of them have had that strap.
I had a 73 Road Runner with a center console. No strap on mine either.
Must be a customization added by someone.
They were on a 74 Road Runner I have. Part # 3550160. I was able to get 1 NOS about 20 years ago, haven't seen one since.
Not available. Most of consoles got the provision holes for the seatbelt straps, but some other didn’t. You can see on them a slight mark or dimple on those without the hole already opened.
As mentioned last NOS set I also have seen was maybe 15-20 years ago.
Mostly sure once they got break back on the days never were replaced since is not a critical part so maybe factory never took care about get enough stock of replacements for them.
Thank you for the info. I’m going to have to make one then.
Not original to my car but I picked one up decades ago and of course moments after installing it I accidentally broke it while pulling out the drivers seat not realizing the strap was stuck. Been looking for a replacement as well, tried repairing mine so far no luck.
Also look at other makes and models for the strap, heard on suggestion to start with a black zip tie and try to make one.
I got a 72 Charger Rallye that is kinda of a survivor car, and those are intact and in perfect shape.
Here are pictures of both the right and left side of my console with both sides intact. I can definitely see how these would very easily not survive
Years ago I got a bunch of parts from 73 or 74 RR can't remember but the 4 speed console had them. They are factory pieces for sure. I kept them cause they were so nice and not brittle..
I’m looking at using push mount zip ties. The downside is the strap isn’t smooth.
Yep that's a factory part that both of my 72 Satellite Sebring's had, I even had NOS spares for a while but gave them to a friend in a package deal.
Ron
