Hills and curves are so much fun. Smiles/gallon is what you need to look at.This side of the state is a little bit, yeah.![]()
Ain't nothing wrong with those old "Magnum" V-6's (V-8s with two cylinders lopped off, but sharing a lot of internals).Lots of cars of the 50's had OD's in them. Thought that was a bit odd with the way gas prices were back then but on the other hand, it saves on wear and tear. Both of my 1st gen Dakota pickups are V6's and with 235/75-15's, if you're not doing 80 when hitting a bridge, the will shift out of OD. Both trucks have 3.55's and just don't have the nuts to pull taller tires but they do with a tire that's close to factory tire size of 205/75's and get better mpg but if you go even smaller (I've done that too), the mph and the pep gets better. Imo, the V6 should have come with 3.90 gears at least and would be even better with say 4.30's! Had a 92 Dak with the 5.2 and 3.90 gears that pulled down better numbers when driven brisk with 12mpg being the worse in town when being meaner than hell on it but the V6's will get just as bad or worse when being mean to them.....ask me which one was more fun!!
Until they get a bit icy in the winter time....Hills and curves are so much fun. Smiles/gallon is what you need to look at.
True dat. Fortunately, we don't get that much 'round he-ah.Until they get a bit icy in the winter time....
Yeah, the V6 isn't a bad engine at all and imo, I think it's a good step up over the /6. The V has more pep too and should have with the little bit of extra cubes. Had a 74 D100 with the /6 and no options and it would pull down good mpg IF you had an egg under the loud pedal but the D series trucks were heavier than the Dakota trucks but mpg numbers were pretty much the same as the Dakota when driven the same except that I did squeeze out 20 mph with that old pickup one time and that drive was the most boring tank ever! My /6 67 Dart would pull good mpg numbers with the 3.91 gears in town...I'm talking about 20+ without driving with an egg under the pedal but it sucked gas on the highway. Thing is, it wasn't on the highway much. And of course, we didn't have to contend with the ethanol bs that everyone knows (or should know) that even the 10% crap can reduce mpg by 15%! At least that's what I noticed happening in my stuff when it first started coming out.Ain't nothing wrong with those old "Magnum" V-6's (V-8s with two cylinders lopped off, but sharing a lot of internals).
Yeah with modern OD's - the '04 Ram 5.7 of mine (bought new back when) came with 20's on it (ugh) that Dodge was
actually selling with 3.55's at first.
They eventually came to their senses and made it a mandatory option to get 3.91's when those 20's were selected....
which mine has, but to be honest, with two OD gears in the 545RFE, a higher numeric ratio still would probably have
been better.
The OD is so severe in that transmission (plus lockup convertor, of course) that I'm thinking at least 4.10's or even more
would be better.
As it is, around town and up to highway speeds, I just keep it in "tow/haul" mode to keep the convertor unlocked.
