Meep-Meep
дворянин
The 9" has longer ring gear teeth and the lower pinion requires a different helix cut, which I believe takes more load off of the pinion bearings. Yes, the 9" pinion bearings are smaller than a 741, but we are also talking about a very different design.
I believe the reason the 9" became the industry standard is they are easy to set up, plentiful and overall a strong unit. The track lock is the weak link and if you will do anything serious you need the billet carrier.
I have seen 741's go through some abuse and come out OK but there is also a reason the factory made the 742 and then the 489.
