440 PHIXX
The Island of Misfit Mopars
When did the “CH8” appear on the drivers side heat crossover? This one has it, so it must have been soon after A12 production.
It was CH6, and that was the aftermarket EDE manifold, not the OEM A12. Although they are the same.When did the “CH8” appear on the drivers side heat crossover? This one has it, so it must have been soon after A12 production.
Thanks. My ‘70 Charger has the “wrong” intake manifold. It’s the aluminum version without the “CH6”. I’m OK with that. My ‘Cuda has the “right” cast iron one... it weighs a ton!
Agree. As I understand it, the ch6 was on the aftermarket version from edelbrock. The guys that wanted to pass off their clones as original weren't happy, cause a knowledgeable viewer could tell, from ten feet away.Actually if it doesn't have CH6, but has the Mopar part number and Penastar, it's the OEM one. That would be an A12 manifold. Some early '70 six pak cars got the aluminum manifold before they switched to the cast iron.
So yours had a CH6 cast on the runner? No Mopar markings?I have the original from my A12, and also a ch6 with no part#, lousy decorative details, and horrible core shift, along with terrible port openings.
At least it was free, and nothing a few minutes with a die grinder won't fix.
Edit: and the wonky "6" on the part# is the real A12 giveaway.
Thanks but these are oem style vacuum secondaries, and just in case you were thinking about it yourself Mancini sells a new set up complete with linkage et al’ for $2500 on the RB and $2400 for a B intake version
Oops, looks like @70chall440 and I were typing at the same time but he hit the post button first. Yes as challenging mentions they are all available new from Mancini for a good deal. I think right now you can get 10% off with discount code #Holiday Thanks.
Good to know! Thanks!Just to make sure you are comparing oranges to oranges
Sixpack Performance Package includes the Air Filter & breather
MANCINI DOES NOT
The breather is an additional $420 on sale $499 normally
I think they are out of stock I have been looking and no one has any in stock .I remember "back in the day" when you could order these from DC. The only guys I ever saw run them were racers, the progressive linkage could be a bit problematic to get just right but once you did they worked pretty well.
This fantasy that in stock form everything was perfect or as good as it was going to get is just that, fantasy. The factory (every manufacturer) had to make compromises to get cars on the road but the after market was/is there to help. Stock cars while interesting are boring and far from meeting their potential which is why the vast majority were modified almost as soon as leaving the lot (or even before as many dealers offered "speed" upgrades in-house). We would not have companies like Direct connection, Grand Spaulding, etc. without a serious dose of hot rodding desire. Performance and modification are the hall marks and life blood of the muscle car world which is why returning them to stock does not make sense at least to me. I can respect a restored car but it has no interest or appeal. Of course this is just my opinion....
Sorry to get off topic... As to the value, its completely up in the air IMO, seeing that you can a brand new setup from Mancini right now for $2500, I would have to say less than that.
Nobody sells the 4782 and 4783 carb setup anymore. They were over the counter carbs back in the day by Direct Connection. To the op, I might be interested in them.I think they are out of stock I have been looking and no one has any in stock .
