Fill the end of the tubes with solder or jb weld, then drill out to the original size.I had a spare vacuum switch, and I opened it up since it was in bad shape, and the nipples have a larger inner diameter than the holes on the flip side of the nipples. So, if I drill the holes out to put in the brass tubes, I wonder what that would do to the function of the switch. Plus, if I go with very small tubes to keep the orifices the same size, then the vacuum hoses won't fit.
And I went on ebay, and the only ones that were listed were not right for my car.
