m79ded
I got the wideband guage today. I'm going to buy a vacuum guage as well. I'm going to mount them where the ashtray door currently is. I don't smoke, so this is as good of a place as I can find. I bought ABS pipe and some pebble grain 3/16" plastic sheet. Stay tuned. I'll post pics as soon as it is done.
M79ded: That Lunati cam seems milder than what I have now. I am not nearly as knowlegeable on cams as you may be, but I wonder how that might work with 53 more inches than a stock 440. I guess I'll have to call and talk to the techs at Lunati. Thanks for the suggestion.
With that many cubes, it's actually not a big cam and milder than what you have now. but with that said I believe it would make a difference in your car.That cam will pull very strong to about 5600, but most of all come in under 2000. With your converter and the final drive ratio you have,lots of your cruising is done in the 2000-4000 range. The milder cam is going to work better in that range, build better vacuum and much smoother drivability especially When you are at highway speeds and converter is locked up you are going to smash the pedal and that thing is going to be in it's best power range and man is that going to go.
To sum it up much more efficient.
