Junky
I've done a lot of research on this topic, but I'm in now way an expert. Our old style flat tapped cams and lifters need zddp. Our stockish or mild engines are OK with 1000 to 1200 ppm zinc. The more the cam lift with stronger valve springs and other mods, the zinc ppm should go up. Recent oil analysis show that Shell Rotella T dino oil still has about 1200 ppm zinc, synthetic closer to 1400 ppm. Most all of the heavy duty engine oils (aka dino diesel oil) have about 1100 to 1200 ppm zinc. I run a 518 lift cam in my 383. I run 15W40 Shell Rotella T dino oil with a bottle of STP. I like heavy engine oil for the summer because I do a lot of highway driving. With my low gears I'm turning 3000 to 3500 RPM down the road. STP has a large amount of zinc. I broke my cam in with Shell Rotella/STP.
BTW, standard oil like 0W20, 10W30 and such, the kind with the round "star" on the label, have virtually no zinc, or none at all.
