What parts from 73 satellite disc brakes can i use on 69 charger
Spindle and rotor.
Caliper bracket in 73 is pin, and no pin caliper clears the sway bar. 73 up caliper also dosn't fit any 66-72.
Standard combo is A body disc setup with slider mount, caliper to the rear. Although I like 73 up spindle as its taller.
73up B brake hose, with an extra twist.
I used the spindles and pin calipers from a 73 on mine, mounted to the rear. Modified the steel brake line so the rubber hose would cross th axis of steering properly. Used the large pin bracket and rotor from a 76? Car for the 11.75 rotor.
