- 4:12 AM
- Feb 22, 2013
- The Red Anvil Dog House
Hows the heater working?
Must have in Boston this time of year.
The kinipler pin breaks, the current then reverses and runs upstream, and that shorts out the binary redinculator, causing the zizzle wheel to counter rotate on the wobble rod...High voltage in the water pump can also cause early failure of muffler bearings. If you have a 6 volt system, the taillight fluid will dry up too quickly too. I switched to 12 volts simply to avoid that crap.
It's like fraternity hazing...Laughter is a wonderful thing and I will admit I had some good laughs... but you guys sure know how to drive off a new member..
