Mike67
So I posted a while back that my motor started making a hack of a racket, It only has about 30-45 minutes of idle/ reading time irn it.
I pulled the motor a couple of weeks ago and started tearing down the top end and this past weekend tore the bottom apart.
I had figured it was the idler gear axle grinding on the block but when I removed the cover found that the cam button was missing and the cam had walked forward allowing the bolts to grind against the cover sending aluminum about the engine.
The brand new pump had aluminum embedded in the walls of oil pump eccentric. The cam bearings are toast yet the journals look fine as do the hydraulic roller lifters, the cam lobes show some wear on the edge of the lobes, I assume from the cam moving off center.
When I pulled all of the rod caps they (bearings) all showed some slight,( very slight), wear, the weird part was that the journals & mains look brand new. The rocker shafts and rocker bushing showed no marring either. Pistons and walls look freshly machined.
I was pushing out a piston and my F.I.L. dropped the piston and broke the top ring, no damage to the piston as I had laid a layer of cardboard under the motor while I disassembled.
The motor is a 440, pretty stout, 10.5cr, eddy 84cc heads, KB236- .010, cam is a Hughes H-Roller 555/548-246/252-110°LSA. Crank has already been turned .010
So my question.is do I just have it boiled, new cam bearings installed? Of course new rod and main bearings. Does anyone polish cams? I would hate to have to purchase a new one.I do have a new unopened new XE275HL K kit sitting in the cabinet but seemed a little tame for what I wanted if the cam is toast, but I need someone else to look at it and advise on its condition.
Should I have the block re-decked? Are my Cometic head gaskets worthless now or can they be reused?
Also should I replace all the rings? Or can I source a single somewhere?
Thanks in advance!
Thanks in advance!
