Photon440
- 11:53 AM
- Mar 14, 2012
- Surrey, B.C. Canada
I'm not going to vote scrap or save until you know more. The worst pictures are of the heads, but the question is about the block.
I would pull it apart. If it is still standard bore, then after hot tanking and boring the block it might very well be fine. But you have no idea until you pull it apart to check mains, bores, etc.
Junk it ....not worth anything or even the effort73 400 2V nothing special. Sat outside with no cover and the valley pan rusted out. This is the second one I've had like this.
Allot of work to get the cast crank out.
Heads are toast. Heads bolt are going to have to cut off.
Cylinder condition unknown but guaranteed to be rusty. View attachment 1213065 View attachment 1213065 View attachment 1213066 View attachment 1213067 View attachment 1213068 View attachment 1213069 View attachment 1213070 View attachment 1213071 View attachment 1213072 View attachment 1213073
I don't believe it is one of the good 230s? Due to date. But I believe a thicker cylinder wall 630 is possible? If so? Give it a try, and clean up the block.We don't know at this point, he hasn't posted casting numbers. But, if it is a thick main 230 or 630, it could be the strongest oem b/rb block Mopar ever made. The '73 date means it could be. He won't know anything about it till he gets the crank and pistons out.
It's up to him if that might be worth the time and effort. If he was trying to build a 700hp 512, it would be.
