They are limiting NHRA P/S, T/F & F/C to 10,000 RPM now
they were all regularly exceeding that last year...
The valve-train Induction & Ignition
really dictates how much RPM can be made
the bottom end & quality of parts tells you
how many times & how long it stay together...
"Mostly stock" parts Wedges BB or SB 5500-6200 would be the max
with any longevity, that's with better valve-train & induction
or ignition too, OEM doubtful for most, with very few exceptions
the heads camshaft & valve-train aren't designed to go much past 5500
My old 526ci {later 540ci} Top-sportsman engine
would spin to 8800-9000 even make power still {not fall on it's face}
nothing in it was really a OE Mopar part anymore either
except the block casting...
BB valve spring killer,
0.850"+ gross valve lift +0.0100 longer valves & beehive springs
440cfm intake flow, Hogan sheet-metal intake & split Dominators
Callies crank, Oliver rods, Venolia pistons Child & Albert rings & Bearings
4 bolt splayed Billet main caps, ARP Hardware studs everywhere
My current 479ci 6bbl is good to about 6200rpm,
it'll pull past that easily,
but doesn't make any power beyond that point,
peak torque is more like 5600rpm,
above 6200 it just more likely to hurt parts & noses over,
makes less power/torque, so why spin it over that...
Usually with a Mopar wedge you'd run out of port design 1st,
not designed for those RPM's
IMO Most highly modified & ported {fully worked heads}
wedges about 7500 would be max,
of course depending on valve-train & heads capabilities
if the lower end stays together,
with good internals & really good hardware/studs, rod bolts etc.
maybe
an aftermarket block, 4 bolt splayed mains,
a girdle, thicker main webbing,
&/or 6 bolt Hemi style mains,
lightweight aftermarket crankshaft & rods/pistons,
are all mandatory pretty much past that point
Hemi's, mainly full race prepped engines have been doing it for 50 years
Sprint Car or Cup engines do 9000+ regularly for hundreds of miles now
depends on the parts, cylinder-heads/Valve-train are an integral part
There's a lot of BS #'s alleged {lies} over the years too....
