detmatt1
Does anyone know where the Dodge B-bodies are 1" longer than the Plymouth?
I was told the rear spring perches are mounted further back on the Dodges. I am restoring a `68 Roadrunner and in the process picked up a doner `68 Coronet. I no longer have the rear frame rails to the Dodge but I do have the full rocker assemblies from front of rear wheelhouse to rear of front wheelwell and they are identical to eachother. Including the location that the front leaf spring perch is spot welded to it. Furthermoore, if the rear leaf spring perch were mounted any further back on the rail it would extend past the end of the rail. I am looking forward to some input.
Thanks all in advance
