not so famous bob
Sniper user here. I put the ignition box under the battery as well but I made a mounting bracket for it. Obviously can't see it behind there but it faces forward so the connector is facing front. You can see the wires poking out a little.
I put my coil on the passenger side inner fenderwell.
The handheld lives in my console.
To be clear, the harness that comes with the Sniper leaves a lot to be desired because it was most likely designed around a small block Camaro. NOTHING was good or easy about it, the wires were not long enough, the fuses and relay were all bunched together to just hang there on the firewall... my fuel pump relay is now under the dash.
If the people who designed the harness had a big block B body in their shop and tried to install one they would have been appalled at how close to impossible it is to make it work without resorting to doing outright stupid things.
I literally removed every wire from the connectors and started over from scratch so I could put stuff where I wanted it.
Same with the fast 2.0 system , wires were long enough , the throttle body to ecu being the worst in my opinion , and the ext. fuel pump wires had to be extended a little , which was no big deal .
The plug ins were all gm , and had to be changed to mopar , with exception of the headlight plug ins.
The throttle body needs a plug so a guy could unplug it when removing the intake and or heads , and lay it out of the way on a bench , with the ecu in the cab , have to lay the throttle body aside best I can , in which the wiring isnt long enough to really do that .
Had the wiring pretty neat , after rewiring the whole car , then decided to switch to the efi , now its a mess again, but works ----------
