Potts
Any swirls of Oil in your coolant?
If burning oil it will show up at speed when you take your foot off the throttle because high vacuum sucks the oil into the intake. Maybe have someone follow you and take it out on the road at speed and let off gas pedal and see if that is your problem.
Pulled two random plugs and found nice, dry plugs.
Pull them all. An intake leak could be two or four paired intake runners.
Are you sure that you filled the oil up initially? Had to ask.
Daily drivers that didnt get regular oil changes and proper maintenence were known for sludging up the valve covers, which would of course cause drainback issues when you decide to thrash the thing at high speeds..... This was not exclusive to Mopars by any means... I've heard of people throwing kerosene in them then idle till warm to thin the oil before draining the crap out.... I would not be a bit surprised if that trick did more harm than good, or maybe sent all the sludge straight to the oil pickup in the bottom of the pan lol.
