Anyone know if these are still being reproduced? I broke 2 studs off. I may try pressing them out and replacing as I searched and came up empty.
That's the plan - unless they were easily available / reproduced. Just thought I'd check.Can easily be rebuilt with flat top bolts mig welded in place
Did they press out easily or need to grind off the head?
I don't remember what I did yesterday, let alone 6 years ago. LOL. Think I cleaned the heads off with a thin cut wheel in the 4.5 angle grinder.Did they press out easily or need to grind off the head?
I get that! Just figured I'd ask in case it was recent (today).I don't remember what I did yesterday, let alone 6 years ago. LOL. Think I cleaned the heads off with a thin cut wheel in the 4.5 angle grinder.
Just grind off the heads and drive the studs out. Weld the new ones in. Take it to a welding shop or a friend with the tools if you can't do it yourself. You could use a hex head bolt, a carriage bolt, a stud, or Ready Rod as long as it's welded on to secure it. You can grind down the head and weld if needed.I get that! Just figured I'd ask in case it was recent (today).
Everyone is differentDid they press out easily or need to grind off the head?
