SublimeSixpack
What is the recommended ATF for a Mopar A999 trans. with electronic activated lock-up torque convertor?
Dexron 2 or 3.
I actually run Ford Type F though. IT is supposed to provide firmer shifts.
wyrmrider beat me to it....
Viagra or Cialis is good stuff. If you need a firm shaft, get a prescription and warn the wife that you are on your way home.
Back in the 1980's when cocaine was popular in the party scene, it often made it difficult to "get up to speed". It didn't matter what you used for for lubrication.
WHAT?What ????
My first wife had a 75 Pisser I mean Pacer. Some cool innovations were built into that car. Lots of glass but very little wind noise for the day. Longer passenger door than the drivers door for ease of entry into the back seat just to name a couple of things. Too bad they turned out to be pieces of junk.....In high school my daughter drove the 77 Pacer Wagon- wife bought new
we live at the bottom of a long downhill driveway and rear band life was not too good with daughter firing up the Pacer and flying backward up the driveway before the converter even got a chance to fill- transgo kit helped with that
but answer was 999 guts out of a Dodge cop car into an AMC V8 case-- double wrapped band, more clutches what's not to like
I have an RV converter- did not have time to do lock up but I also have a 518 from a jeep and an AW- 4 od trans also out of a jeep and a 4.0 EFI motor- another project
good luck with the 999- good trans
