The problem is there is no "perfect" cam. Everything is a compromise, and how you prioritize what is important to you.
I looked at the head flow numbers on Stan Weiss' chart, and stock, they don't look good.
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water -- DFW / FLW Flow Files for use with Engine Simulation Software
I got interested, so I started looking at the actual numbers.
I just started the calculations, so I will try to finish tomorrow.
I need to double check the compression ratio / piston heights.
On your stock valve springs, have you checked the seat and open pressures?
One guy wanted me to install the Mopar 292/0.509" cam with his stock valve springs that only had 70 pounds of seat pressure.
I had some 440 source springs off a stealth head that I used.
