Here's a copy of an old post with the jetting. The 1407 Eddy's are pretty close to a 3705 Carter's
dvw said:
Here's what I used. If you notice the small secondary jets on the 3705's are in the outside of the intake. One carb faces in each direction. The 3447s are the same side to side. These were Chrysler dyno jet numbers done in house under controlled conditions. Take for instance the .104/.053 jet/rod vs the .089 jet by itself. The difference in area is only about 3%. So beside the choke side secondary jets being small (cylinders 2/7) not much difference. My car ran 10.1X@132 best. Your issue might be lack of hood scoop. Not the the scoop is that great, but the carbs are very close to the hood. Like I said, not much difference.
Doug
1963 Stage III 426 Super Stock cars with the 3447 Carter carbs:
Main jets: Primary = .098"
Secondary = .082"
Step-up (metering) rods: .068 X .050
For the 1964 426 Max. Wedge cars with the 3705 Carter carbs:
Main jets: Primary = .104"
Secondary = Choke side .063" Throttle side .089"
Step-up (metering) rods: .066" X .053"
Also, on these carbs (the 3705s), the recommended float setting changes from 7/16" to 7/32"
Doug
Secondary = .082"
