Which clutch should i use
dodge68charger
8:03 AM
Washington
Gonna mate my transmission to my engine. The engine is a 440 with a a-833 4 speed. Not looking for a heavy clutch.. Heard mcleod is supposed to be good. Which one you guys recommend
I just put a McLeod Borg & Beck style in my Charger. It has a little stiffer spring than stock, but not to bad.
You will be very happy with a Centerforce Dual Friction. I installed one in my wife's Challenger 10 years ago. Car has over 100 drag strip passes on slicks. It twisted the axle shafts but never phased the clutch. It never slips or chatters. I removed the over center spring under the dash and pedal pressure is still lighter than a old Borg & Beck. The car run's 12.50@110 and weighs 3750
Doug
you will be very happy with a centerforce dual friction. I installed one in my wife's challenger 10 years ago. Car has over 100 drag strip passes on slicks. It twisted the axle shafts but never phased the clutch. It never slips or chatters. I removed the over center spring under the dash and pedal pressure is still lighter than a old borg & beck. The car run's 12.50@110 and weighs 3750
doug
ditto....................mo
I have the older Center force II in mine for over 10 years, best clutch I ever had. If I ever have to replace it will go with the dual friction.
