That is definately a good way to go, but I was thinking a few hundred bucks from a junkyard and a couple hundred bucks to have it cut down when compared to a new 2000 unit.... Am I wrong with the price of a used truck dana?
You right, but IMHFO it will cost more than just a couple hundred... If you have the necessary skills & tools... But if there's a will, then there's always a way, you can get creative, think outside the box, maybe you will come up with something cool for 1/2 the cost... Teach us all something cool... I think the Strange
base set-up is like, starts @ like $1500-$1800 complete, then you can use your 8-3/4 brakes {if it has the proper std. style ends} & it's a bolt in... Remember the truck rears that are "cheap", are the floating axle types, like 8 lug 3/4-1 ton units, everything has to be changed from the, axles, ends, bearings, mounts, brakes {yoke maybe} etc... I've done it both ways, several times now, in the future I'll do the Strange S-60 anytime I do it again...
good luck what ever you decide my $0.02 cents
axles $300 min. probably more
ends $100 min. ballpark
jig for welding $100 min. welder & consumables to preform the task & your time/knowledge or effort
perches $100 min. ??
axle bearings $50 min ?? pressing them on & taking them somewhere, time gas effort, if you don't have the tools to do it yourself
A boneyard Dana-60 axle housing $250 min. ?? if you can find a place that will sell one that cheap, probably needs complete rebuild, time to go & get it, gas to get there & back another $50... Craigslist or E-Scam maybe another option
rebuild carrier kit $150 min. easily {sure/true trac ??}
seals & silicone & paint $25 ?? easily
shock mounts $10-$25 min., fabed up maybe cheaper ??
yoke $100 or drive shaft end change & shortening/balancing $150 probably, maybe a little cheaper
Now we're up to $1385-$1400 for an old unit & your time, now probably more, lets say 10% for cost variances now your up-to $1475-$1600ish + or - taxes, shipping, gas etc. lets just call it $1500-ball park easily, not saving all that much here...
to do it right... but I could be wrong, wouldn't be the 1st time won't be the last, either...LOL...
Probably being overly ****, BUT
I'm sure it can be done cheaper too, possibly too, just an example of what it could run you, for an old unit... food for thought
