Which Headers fit on my 64 Fury ?
moparfreak92
8:46 PM
Kiel
Hey Guys,
which headders fit on my 64 Plymouth.
-383 Cui + Milodon 31010 / 727 TF + Deep Pan
-Power Steering
thx for Help!!!
Greetings from Germany, Tim
Here's a set from TTi, there pricey But everyone say's they fit the Best, remember
62-65 B-Bodies are NOT the same as 66-70 B-Bodies so when you buy them make sure there for that rang of year...ill be getting a set from TTi this week !! Good Luck
http://www.mopartsracing.com/parts/tti.html
TTI said, only this one fits? but i want to buy 1-7/8 Headers.....
1-3/4” BIG BLOCK HEADERS 1-3/4" O.D. primary tubes with 3" collectors
Designed to fit 1967-1976 A-bodies, 1962-1974 B-bodies and 1970-1974 E-bodies with 383/400 B-engines and 440 RB-engines
Fits Stock Heads and Edelbrock Aluminum Cylinder Heads
You may have a problem. I can't find any company that makes 1 7/8" headers for a 64 B body. If this is a mild street car, 1 3/4" will work great. It's possible that headers for a later application will work but you have to have the means to modify them, meaning cutting and re-welding...
1-3/4 headers will work fine for you. I had 1-3/4 headers on my old 906 headed 440 in my 63 and it ran as fast as 11.49 @ 116 using the 1-3/4 tubes. They will work fine for you. Ron
Go With 2" Then...
2” BIG BLOCK HEADERS
2" O.D. primary tubes with 3½” collectors
Fits 1967-1976 A-body, 1962-1974 B-body and 1970-1974 E-body applications
Fits 440 RB-engines with Stock heads, Edelbrock aluminum cylinder heads, Indy 440EZ heads, Stage 5 or Stage 6 cylinder heads. Also Fits 383/400 B-engines (low deck) with INDY440SR cylinder heads
• Will not fit A-bodies with Stage VI Heads, Will not fit RB-engines with INDY 440SR heads
