Which Motor Mount Brackets do I need?
Joel Talka
3:56 AM
Ocean Breeze Florida
OK, I finally took delivery of my small block LA engine (408) and am gearing up to install it in my 1966 Coronet. I have motor mount brackets from the 318 which I took out but do not fit/align with the new block mounting ears.
The engine block is part# 53020006 (360) and the K member installed in my car is stamped 90 on the coin (2962090). Can someone tell me what the part number(s) are for the proper motor mount brackets??? Also, where can I find them?
Thanks,
Joel
You'll need 360 mount brackets (LA 360 brackets will work on your Magnum block). Try Mancini's
