On a side note, since on this topic, when I had troubles with higher engine temp doing some research, found that a higher mix of coolant can elevate engine temp. Obviously, up here in the north we need to be concerned about cold weather. Typical here is a 50/50 mix. For my old Plymouth, it only is driven during the warmer months and sits in a heated garage. So I reduced the mix to around 35% coolant and engine temp lowered. Well, I did several things given the added HP after rebuild; 7 blade, found an OEM shroud, top seal, but did the coolant ratio last and seemed to have an impact. Oh, did some changing with oil visc too.
