WileE
- 8:01 PM
- Sep 15, 2009
- State of insanity
Indian head. No gasket leaks over 45 years on mine or others jobs.
Did you fill the retainer bolt holes with RTV? Look and see many times the pan barely covers that area.Hey bud, I installed one of those one piece trays also. I fired it up let it run 15 minutes, drove it 2 miles, shut it off, checked before I got in, drove it home, parked it in the drive( slight incline ). I started cleaning the garage, looked under the car, there it was. I pulled it back in, started looking, it was from the back. When I pulled the pan again, I think it's that large lip on the back of the tray that causes the oil to puddle. I used rtv to glue it to the block. Unfortunately I haven't had a chance to finish and drive it. That's happening this weekend, I'll let ya know. Take care.
That is probably my problem. I see the alignment pin is properly aligned, but I know for certain I have some seepage there. I'll probably tackle this in the fall.I chased a oil pan leak for years
Didn’t realize it until I pulled the timing chain cover off finally one day
When the timing chain cover got pushed on during the last rebuild at the machine shop , either the alignment pins where out of round
Or the timing chain cover alignment holes where full of paint and not cleaned proper , bottom line those holes on the timing chain cover where pushed out when the timing chain cover got installed or pushed on , so those areas never sealed proper with the gasket flush
Oil was running vertically down from the timing chain cover , getting on the oil pan gasket , working its way backwards towards the transmission making it look like everything was leaking
Now that's interesting. I kinda like that idea
Had this taken care of before I built my new motor over the winterThat is probably my problem. I see the alignment pin is properly aligned, but I know for certain I have some seepage there. I'll probably tackle this in the fall.
