Eastwood is a restoration supply website. i think we was referring to using an eastwood product for the removal or the seal. Not sure what he was talking about and I buy a lot of stuff from Eastwood. :christmas_presents:
has anyone tried a gasket made by precision. I've heard that softseal are bulky and ill fitting or is that not the case.
Even better is it possible to get a nos one
thx
Softseal is supposed to be a good seal. When you reinstall keep in mind you will need to use sealer on the bottom edge especially in the corners. For removal use a razor to remove all of the seal that covers the glass and then work a wire through and then use two people to cut the seal with wire with a piece od wood on each end of the wire for grip. Take your time and don't force it and you won't break it.
