Who makes Year One's seat covers?
Update-
Two weeks ago, me and another friend helped my brother put PUI covers on his 66 sat.
Was not as difficult as I expected. We also replaced the foam.
Look was good, fit was good except there was a lot of extra room at the top corners.
So much so that we wondered if the Charger buckets he had might be different than Satellite buckets.
Other than that, which we filled with extra foam, and a few wrinkles which we hope will smooth out with a few heat cycles, they look good.
I went a head and used a discount code found here! and got Legendary covers from Classic.
Last week, I did the top of the back seat, and it came out pretty good, again with just a few wrinkles I think will come out with a heat cycle.
The Legendary does appear to have a bit softer feel and thicker padding, but that might be dif between 66 and 73/74 design. I did not use new foam, as what I had was 99% good.
Magnes- those do look good. how did you go about working out the wrinkles?
With the discount code my order for both fronts and the back was about $520 including shipping.
Update-
I heated it with my fiancé's blow dryer, readjusted the cover, and used the blow dryer again to warm it up an smooth it out.
They still aren't absolutely perfect but look good enough for the girl's I go out with!
Thanks.
tell me more about "adjusting".
I just have a few creases from being stuffed into the shipping box, and a few small wrinkles from stretching.
I'll see if I can get a pic.
OK, does anyone have pics of PUI installed in a 72-74?
I'm still leaning toward Legendary, but after seeing my bud's car, I like the way the PUI's turned out.
I priced Legendary on Classic Industries, and it was the exact same SRP as the Legendary site, and they wouldn't show you shipping until you created an account. Because it was over $500 for the fronts and rear, there was 5% discount.
YY1 we are trying to help you. Stay away from PUI. Go to legendary thru Dantes. We are speaking from experience.
Like I said- the PUI my brother bought turned out pretty decent.
I am working on getting the Legendary I bought onto my donor seat frames :)
