Who did you have rebuild yours and how did you like the price and results?
That's what I was thinking. Did you do a write up on your rebuild?I went thru my 65 Coronet A/C compressor, just to make sure all was well. I have done these in the past and they are very simple. Get a service manual and do it yourself. It will probably only require a gasket set. And of course, a front seal (Do not touch the seal mating surfaces with your bare skin!). Lube with the oil compatible with the refrigerant to be used.
Mike
No. It's just routine maintenance.That's what I was thinking. Did you do a write up on your rebuild?
