zdillinger
I have a rather annoying noise coming out of the rear of my '73 (318, 904, 2.71 8 1/4). It almost sounds like a dragging brake, but I'm certain that this isn't the problem. The pinion moves freely, no noise / sloppy movement so I don't suspect this. I've never moved the pinion or the ring gear, so the backlash / pinion depth are unchanged. However, there seems to be a fair amount of slop between the axle shafts and the carrier (i.e. the ring gear spins a bit before the axles start to turn). I don't see a spec on this, so I'm unsure if this is ok. Also, it appears that the spider gears move a bit laterally when the pinion yoke is spun in one direction and then the other (the source of the slop?)
So, my question: if the carrier pin that passes through the spider gears is worn, could this create enough slop in the gears that a gear-slop noise would be present (quite loud)? I've already replaced the axle bearings and the problem still exists. If it isn't the cross pin, I wonder if it might be the output shaft support bearing on the 904. I hope not...
EDIT: One more question: can anyone tell me where the vent for the 8 1/4 is?
