Wiring Question?
dodge68charger
6:56 AM
Washington
Im Running a 1 Wire Alternator With a 6 Gauge Wire Going To The Starter Lug..
should I Put a Fuse In Between The Starter and Alternator?
Its a 140 amp Alternator..
Also From The Starter Lug Im Running a 8 Gauge Wire To My Fuse Box For a Main Feed For Power..
Should I Fuse The Wire Between The Starter And Fuse Block? Thank You
In this case I believe you will be fine without fuses if the wire is properly routed and protected.
Mike
