cudak888
I plan on pulling the worn-out (22psi wet/dry compression when cranking in worst cylinder) 318LA out of my '68 Satellite in favor of a junkyard-sourced Magnum 5.2 or Magnum 5.9. This said, I want to run my shopping list by the experts to make sure I haven't missed anything.
Requirements of the swap (to suit my tastes) are as follows:
I wish to stick with factory parts as much as I can, thus giving me an edge at the junkyard (and in the pocketbook). If anything sticks out as missing or wrong, let me know.
Modify Magnum 5.2 as follows (since I'm using this as my shopping list, I've also noted to myself where I should find the parts):
One of the things not on this list and not clarified yet is whether the Magnum clutch fan will fit - and which radiator shroud will work for this updated combo.
Exhaust on the existing car is trash, so I'll be using the Magnum manifolds without worry of exhaust fit.
Have I forgotten anything?
-Kurt
- Must be carbureted
- Fuel pump must be mechanical
- V-belt accessory drive
- End result must allow for a Sanden A/C compressor to be used with factory or factory-like brackets
- Mates to an A904 transmission
- Roller cam from 89-91 LA 318 w/long snout (junkyard donor - avoids Hughes cam extender to drive fuel pump)
- LA fuel pump eccentric (junkyard donor)
- 1979-90 LA timing chain cover (seal from front, timing marks on driver's side - my cover is a '67-earlier with a bolt-on tab) w/stock harmonic balancer (separated pulley style for V-belt conversion
- Factory weighted flexplate (if Magnum 5.9 - does not apply to 5.2 swap)
- LA 360 center-sump oil pan (or Summit SUM-G3536) and pickup tube.
- LA oil pan gasket (Milodon crush proof) or Magnum gasket with the ends chopped off and the LA timing chain cover gasket installed in its place
- LA '70+ water pump with passenger-side intake - easier to find (RockAuto) than '69 A/C style and cheaper.
- 1970+ style 26" radiator to match up with '70+ water pump (eBay)
- Bouchillon Performance Sanden left-offset A/C compressor brackets to clear Magnum intake water outlet
- V-belt pulleys (junkyard donor)
- 1970+ lower radiator hose, upper determined by new radiator (RockAuto)
- Edelbrock 7577 intake (eBay - considered the Chinese Speedcrap intake, but realized the LA water outlet wouldn't work with Ram/Ramcharger-style A/C brackets, as those intakes had the T-stat outlet angled to the left, thus allowing the compressor to sit on the right)
- Factory 340/360 SBM throttle cable bracket for 4V carburetor
- Weld extension to factory 2V A904 kickdown rod or source used aftermarket kickdown cable that isn't prohibitively expensive
-Kurt
