drobertson
A while ago I built my 318 with a mild cam. I had it running at 14 degrees and it ran ok. I then tried advancing it to 26 degrees at idle and it runs great at that. Is that safe for a mild engine?
I'm not even sure how much advance there is under load but it runs good.
The engine is 8.6:1 compression, and has a cam with .454/.454 lift and 272/272 duration on both intake and exhaust. Stock heads with 340 valve springs, and edelbrock performer intake. Long tube headers as well. Has a 500cfm eddy carb but will be fuel injected as soon as my efi kit comes in the mail.
I'm not hearing any pinging, but I was curious if 26 degrees initial advance is risking anything. (I set the initial advance with the vacuum hose disconnected from the distributor, and then after timing I hooked it back up. Vacuum for the distributor is coming from the ported vacuum.)
