furryfrog
i guys,
I have some questions and always have an ear open for advice or suggestions. I thought I would post up here and start a thread, more questions will likely pop up in the future.
I am putting a twin turbo 440 clonerunner together. All the exhaust piping is done and mocked up, with wastegates. All the intake piping is done minus the last leg from the intercooler to the blow through carb. The 440 is a steel crank 72 from a motor home. I was planning to run the stock bottom end for a bit, low boost to see how things worked out, de bug, ect, but looked at a few bearings and it has ingested metal sometime (guessing cam) and would not have lasted long, even at no boost with the other upgrades on it. So the crank and block are at the machine shop. All the crank journals have already been turned .010/.010.
The block is in good shape, pistons were easy to slide out of the hole, getting it bored, honed ect. Need to order parts for the bottom end and want to run this by you guys before I start ordering parts. This will be my first bottom end not using stock'ish parts and my first mopar. This will be a 99% street car, driven lots.
Heres what I have now in my giant experiment:
-twin s200sx turbos, part #177268
-twin tial 45mm wastegates, twin 50mm bov's
-intercooler
-water injection- snow performance, Ill start with around a nozzle total of 1200 cc/min, using bug wash.
-440 source heads
-cam is hydraulic flat tappet. SUM K6401 dur/.050-int 224,-ex 234, lobe sep 114, lift int @valve .466, ex.488.
Its a relatively mild cam, It was inexpensive, and gives me a place to start knowing what I have, unlike the stock cam that was in the motor. My idea is to let boost make the power on a mild'ish cam, for better mileage and daily drivability.
-750 cfm, csu blow through carb and hat.
-Holley street dominator intake
-msd 6530
-high volume oil pump (oil fed turbos)
-stock converter in 727( waiting to see where the boost ect comes in before i replace it)
-8 1/4 rear end (waiting to see what gears would make the most sense with the combo before the whole rear end is replaced). Its my guess the gearing will be 0 in --short order once its up and running.
-electric fuel pump and boost referenced regulator.
The interior is mostly done and has a 8 point cage. Still in mid of suspension and steering upgrades, have the parts.
So as for the bottom end, the stock crank is forged, internally balanced. I was thinking about 9-9.5 comp ratio.I know a lot of guys will think its too high, but I am going to be running water injection, it works very well, and the CR easier to lower than to raise with head gasket swaps, I looked and cometic makes head gaskets up to .140 think for BBM, they are pricey though ( not concerned about quench really). I don't want the car to be a dog off of boost, its a heavy beast. The turbos are good for 800 hp added together but will most likely keep it to 650, reading on here more than that is pushing the block and stock crank too much. So I'm guessing this combo N/A with this cam will make 350-375hp? (perhaps the experienced mopar guys can comment on this?) so 650hp will be around 12 psi(an assumption)
Heres what Im thinking
-440 source fluid dampener and flex plate, new timing chain and gears.
-440 source platinum series H beam rods with arp 8740 bolts, 6.760" in lenghth, .990 pin size
- thinking of going with clevite V series bearings, being a street car, with a flat tappet cam.
piston, well I do not want to wait months for custom pistons so from the looking around, there is not much to choose from
-probe part #14797-030, reverse dome -12cc, seems like they are over a month away if ordered through summit though, I will phone around on monday.
http://www.probeindustries.com/Chrysler_440_12_0cc_Reverse_Dome_SRS_Pistons_p/14797.htm
- icon dish 12 cc, dish 2-3 weeks through summit
http://www.summitracing.com/int/parts/uem-ic836-030/overview/make/chrysler
-JE dish 18.1 cc, probably 3 weeks away and expensive!
http://www.summitracing.com/int/parts/jep-232456-8/overview/make/chrysler
Thinking of calling diamond, they have a 13cc dish, comp height 2.065, .990 pin part # 52402, which would work and there catalougue says they stock, no idea what to expect for pricing though, I'll phone them tommorow.
Well with feelpro 1009, .039 gasket thickness, gasket bore of 4.410. 440 source heads at 80 cc, 3.75 stroke, piston deck clearance of .020.
I get CR of 9.56 for the 12cc
CR of 9.49 for the 13 cc
CR of 9.10 for the 18.1 cc
Does this seem right to you guys?
Thinking of going with the ones more readly available and best price wise. Leaning away from the JE, over 900 U.S without rings. Diamond may be readly available but not sure what to expect regarding pricing. What do you guys think? any suggestions? Can these rods and pistons be balanced on a stock steel crank?
Regards.
Here are a couple pics from about 2 weeks ago. I was getting tired of working around headers in cars, one reason I went the turbo route. So much room in a b body was able to make all the exhaust piping easy to pull off, even able to use head studs on both sides. Just need to pull one spark plug out on the drivers side to pull the down pipe up and out. will be wrapping the pipes though, the 3 inch downpipe on the drivers side is a tight fit by the brake booster, engine head, and electrical wires. Have new drivers side water pump, 140 amp alt and brakets fabbed and mocked up and most intake plumbing,bov ect, but somehow lost the pics.
-intercooler
-440 source heads
-msd 6530
Regards.
